hi im fairly new to custom water cooling, this will be my first ever custom system...
i was looking for a list of parts (fans not included) that will run on a rtx 2080 ti (any version under 1,200) and ryzen 9 3900X. i would like to keep the cost under $500
and have 2, 360mm radiators. i am planning on using a lian li pc o-11 dynamic so size space isnt much of a concern.
any help will be appreciated, i would like to buy exclusively of off amazon, parts lists would be absolutely amazing
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1134255-help-with-custom-water-cooling/
So that’s $500 usd for a pump/res, cpu block and gpu block?
Prices will be somewhat the same on a card but would need to know what card you’re getting exactly.
Also do you care if it’s cooper or nickel plated? Plexi or rgb?
Do you care about brand consistency?
i will use any card as long as it is under $1200 i could care less about rgb but if the res had some lighting that would be nice
anything as long as im not mixing copper/aluminum, nickel/aluminum I can pay a little more for copper radiators if that is the way to go.
AMD blackout rig
