Coil Whine?
Go to solution Solved by SavageNeo,
3 minutes ago, trevb0t said:
https://pcpartpicker.com/product/rKgzK8/powercolor-radeon-rx-580-8gb-video-card-axrx-580-8gbd5-3dhdv2oc
Here is my exact GPU.
I will state that I don't recommend it to anyone interested in a quiet PC, since under load it sounds like it's about to take flight. (But it is an inexpensive 580 8GB.)
In certain games under certain loads I have noticed that it will whine (a high pitched noise.) for a few seconds at times that seem fairly random. It doesn't necessarily even happen while the fans are going crazy under load...
I have (again) only noticed it in certain titles.
Is what I'm experiencing a "coil whine?"
Is there a simple solution like greasing an element that could mitigate the issue?
Coil whine can occur when power is drawn by huge amount. If it goes from 50w to 250w power draw is seconds it could happen. But its not that normal. You should try to update drivers, update bios, make custom fan curve, or rma the card
https://linustechtips.com/topic/1133777-coil-whine/
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1133777-coil-whine/#findComment-13123018
Just now, SavageNeo said:
Coil whine can occur when power is drawn by hude amount. If it goes from 50w to 250w power draw is seconds it could happen. But its not that normal. You should try to update drivers, update bios, make custom fan curve, or rma the card
Thanks for the input! I'll double check that I've got the most recent drivers/bios when I get home.
I haven't messed too much with the curve. (I believe I ended up setting it to decide on its own.) But I would love to get more into the BIOS side of my build.
Would noise level be something Powercolor would accept for RMA?
https://linustechtips.com/topic/1133777-coil-whine/#findComment-13123034
If you have:
the check of the bought gpu
the model number
your name
They will accept it
https://linustechtips.com/topic/1133777-coil-whine/#findComment-13123039
