HELP SCREEN TEAR !!!!!
I play r6s and I get alot of screen Tear while playing recording streaming no sync of any kind solves the issue I have a144hz monitor and my pc specs are i5 9600k rtx 2060 I tried capping my FPS at 144 didn’t work could my gpu be causing this ? Maybe my monitor? Please I need help should I buy a new gpu bc mine only has 4 gb .please help !!
https://linustechtips.com/topic/1133634-help-screen-tear/
Wich Connection so you use from GPU -> Monitor?
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
https://linustechtips.com/topic/1133634-help-screen-tear/#findComment-13121814
29 minutes ago, FluS- said:
I play r6s, should I buy a new gpu bc mine only has 4 gb
What are the game’s spec?
I only have 4GB RAM on my GPU but never found it an issue. I play Skyrim and a few flight sims plus CSGO and RL.
My freesync monitor keeps me free from tear as long as I make sure I use the right resolution and graphics quality to keep in the freesync range.
i5 8600 - RX 6600 - Fractal Nano S - 1080p 144Hz
https://linustechtips.com/topic/1133634-help-screen-tear/#findComment-13121844
