18 minutes ago, Mythical2 said:
hey, i tried to play a few games with my new rig and the gpu is super unstable, getting some frame drops crashes and freezes. if you know how to solve this issue let me know. thanks for your help!
What games are you playing and what is your system specs?
Also it looks like your voltage is not going up when under load,
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
I tried playing rust overwatch ang pubg. Overwatch ran the most stable.
Ive got R7 3700x
2*8 ram 3600mhz
X470 asus prime pro
850w psu by corsair
Rx 5700xt nitro+
Ive got R7 3700x
2*8 ram 3600mhz
X470 asus prime pro
850w psu by corsair
Rx 5700xt nitro+
I would check and see why the voltage is not going up.
System specs below
PSU: Corsair CX650M
Im really new to this and idk how to check stuff in the drivers and such .. is there a way you could try to help me tomorrow through discord or something?
Try turning off Power Save Mode.
System specs below
PSU: Corsair CX650M
16 hours ago, Mythical2 said:
Its on off already
Which mode are you using?
System specs below
PSU: Corsair CX650M
13 minutes ago, Mythical2 said:
Its just power saving off
Here is something that may help:
https://www.amd.com/en/support/kb/faq/dh-020
System specs below
PSU: Corsair CX650M
On 12/11/2019 at 5:53 PM, Mythical2 said:
Rx 5700xt nitro+
which driver? I'm on a different AIB card, PowerColor, but they all share similar instructions via the vBIOS (with difference of default fan curve settings etc) so mostly related to eachother rather then reference cards.  Recently had to go back to Radeon Adrenline Driver 19.9.2 since the newest driver "2020 edition" caused issues.  I'm waiting for hotpatch on newst driver as it had nice features, better UI, but not worth it if its crashing.
This is the driver i would recommend trying: https://www.amd.com/en/support/kb/release-notes/rn-rad-win-19-2-2
It is recommended you enter safe mode>minimal when changing drivers (whether updating or reverting) and use latest version of DDU to fully remove everything from previous drivers install properly after you have uninstalled it via Windows "Add Remove Programs"
https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Here is how to enter safe mode.
(with current version of Windows 10 just type msconfig in search, no need to use command, and use minimal, not networking like is shown here)
If need be run DDU a few times then go back into msconfig and disable safe boot.
I would also recommend disconnecting/disabling internet until you have new driver installed, windows will try to install its own drivers before you install your own, once you have installed driver you want feel free to reconnect to internet.  This likely won't cause issues if you don't do this, but is a bit prefered method as you are trying to install drivers on a completely "clean" system.
You mentioned its a new system so this might be your issue, that patch came out just over a week ago so likely you have it.
 hey a bit late.. ehh i tried doing that but no succsess.. do you think it could be a windows problem? because thats the only thing i dont think ive changed. my friend just got a cracked windows. do you think it could be the os?
