G Skill Ram - same model, different kit
Solved by minibois,
The reason they would not suggest it is probably because they could be using Samsung DIMMs on one set and SK Hynix on another. That could in rare occasions give compatibility issues.
Usually RAM will just work, even in mismatched similar sets, but as the manufacturer GSkill takes the right precautions to tell you they do not recommend it.
With RAM I always suggest buying it from a place where you know you could (easily) return it, just in the small chance it does not properly work.
Science Studio recently did a video on mixing RAM sets which showed it generally worked fine..
