Finding The Right Case
Just now, 2G_Tony said:What do you think, P600S/Evolv X or Lian Li PC-O11D XL?
I've personally always been a fan of the Original PC-O11D, which was the Case of the year in 2018 by multiple Case reviewers. They kept the theme of the XL version the same, just added more space for more stuff including radiators.
Air cooling GPU's in the O11D can actually be very good if you populate the bottom fan mounts to blow straight upwards into the GPU. No worries there! Between the P600S and the Evolv X, I'l choose the P600S any day simply because you get all the features of the inside, the main difference is the exterior panels.
The PC-O11D XL layout though simply gives you a completely unique PC case perspective you cant get in many other places. That's probably the case I'd end up with if I was in your position.
