I ordered a monitor to be arrived today, but the temperatures where I am living are very cold and will stay in the mid 20’s throughout today, and I’m wondering if that will be a problem for the monitor, I understand I Goulding turn it on right as I take it out of the box, but will there be any permanent damage down to the monitor?
https://linustechtips.com/topic/1130587-monitor-in-cold-weather/
Aslong as your house is.. a normal temperature? It'll be fine.
Only issue might be internal condensation.  If it worries you, let the thing sit inside the box in your house for several hours to warm up before you open it
