Hi. I was wondering what is the very best mic for streaming, gaming and possibly YouTube on the market. I am asking this question because I do not know a lot about audio and there is a TON of choices. Regarding price, it is not a problem but try not to include mics that cost more than 300$.
https://linustechtips.com/topic/1130470-very-best-microphone/
A scalable solution would be to get a small mixer from Yamaha and Behringer and XLR mics. Sennheiser and Audio-Technica are the two leading names in that game. But frankly I don't see why something like a blue yeti or any USB based microphone wouldn't be good enough. Things like pop filters and shock mounts go a long way as well.
Here is some decent starting gear:
Behringer Xenyx Q802USB $97: https://www.amazon.com/Behringer-Q802USB-Premium-8-Input-Interface/dp/B008O517IC/
Audio-Technica 2020 XLR $115: https://www.amazon.com/Audio-Technica-AT2020-Cardioid-Condenser-Microphone/dp/B0006H92QK/
Or All-In-One solution:
Audio-Technica 2020USB $150: https://www.amazon.com/Audio-Technica-AT2020USB-Cardioid-Condenser-Microphone/dp/B00B5ZX9FM/
Blue Yeti Condenser $100: https://www.amazon.com/Blue-Yeti-USB-Microphone-Blackout/dp/B00N1YPXW2/
The Xenyx would also allow for external inputs into your mix and work as a headphone amp and dac.
These are by no means the very best, but good enough, especially to start. The best gets godly expensive.  I would also recommend a good pair of cans, because no one wants to hear feedback. Here are some good starters
Open back- Sennheiser HD599SE $100: https://www.amazon.com/dp/B07RFNZYJZ/
Closed back- Audio-Technica ATH-M50x $130: https://www.amazon.com/Audio-Technica-ATH-M50x-Professional-Monitor-Headphones/dp/B00HVLUR86/
I have the older HD598SE and absolutely love them. Low end is a bit more slacking but your ears do not get hot during long sessions. You can just read the reviews on the M50x to see why they are great. Hope this helps.
https://linustechtips.com/topic/1130470-very-best-microphone/#findComment-13097031
All I can say is I have a blue yeti and I wish I bought an AT2020, and I have HD598s and they're the best fucking things ever.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1130470-very-best-microphone/#findComment-13097078
Rode NT is an option
Crimson Panda
http://pcpartpicker.com/list/g6T8QV
AKG K712 PRO
OL DAC
Magni 3
https://linustechtips.com/topic/1130470-very-best-microphone/#findComment-13097098
