My Rig Please Help Me Improve!!!!!
My first suggestion would be to try re-routing all your cables, hide them, bundle them together to make them look neat and try not to have any just randomly running acros the case. Overall that will make it look better. To help you with the adventure you may want to consider getting a new case, There are many options out there but some good ones are, corsair 650d, NZXT Phantom 410, corsair 800d, corsair 900d, Bitfenix prodigy (small case) Define r4. Now that is just naming a few!
hope this helps
great job too bad the case has no way for you to clean up the cables. What are the specs?
Thanks but when you put the case door you dont see any cables it looks pretty good
Specs
AMD A8 3870k @3.8GHZ
ASUS A75 M LX PLUS
8GB G SKILL @1600MHZ
2 RADEON HD 7770
2 1TB HARDRIVES AND A SSD BEHIND THE MOTHERBOARD TRAY
BTW: i ordered a fx 6300 cpu and new motherboard so the crossfire works better but thanks :)
Specs
ASUS A75 M LX PLUS
2 RADEON HD 7770
I was about to say something about a apu and crossfiresd 7770 until i finished reading xD
lol thanks for your input when i get a chance i will tuck those cables in the back of the tray or when i get the new motherboard and cpu i mine as well order a case and take 1 of the 1 tb drives and and just build another computer right?? lol :D
