Plug the stuff into PcPartPicker, read the estimated wattage, add 20% and then bump up to the nearest 50w.  Anything over that number is probably fine as long as your PSU is decent.
high quality 550W will be plenty for you.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
