I pulled this out of a Dell xps 8900. We reused the cpu and ram in another system because the motherboard was dead.
The psu does have a pcie connection with 2 6 pin power connectors. I'm thinking of using it for a budget build with rx 480 reference and maybe a i5 3770k. Is it worth it or should I just toss it out?
https://linustechtips.com/topic/1129950-toss-it-or-keep-it/
You could probably get a better one.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/1129950-toss-it-or-keep-it/#findComment-13092922
Just now, Sat1600 said:
I have better ones. I wondering if this one belongs in the garbage
Keep it as a spare.
زندگی از چراغ
https://linustechtips.com/topic/1129950-toss-it-or-keep-it/#findComment-13092938
one thing i would never do is recycle a psu for another system EVER!!
if you bought it new and its not too old then you could use it
but if its secound hand then i would never trust it
one more thing is that its a 460 watt psu so i would not expect much from it
Ryzen 7 5800x, eVGA GeForce RTX 3060 Ti XC 8GB, Kingston Fury 32GB 3200 MHz, Samsung 970 EVO Plus SSD 250GB M.2, 3X Seagate 1TB HDD 7200Rpm, 2TB Seagate HDD, Cooler Master V 750W 80PLUS Gold Full Modular Power Supply, CoolerMaster N200
https://linustechtips.com/topic/1129950-toss-it-or-keep-it/#findComment-13093963
If it was up to me, I'd definitely not use it in a pc if it was lighter than a 120mm cpu heatsink.
My R2700XT build:  r7 2700 @4.1 Ghz max 65C - Sapphire Pulse rx 5700xt @1625Mhz 955mV 1300rpm fans, max 82C - Asrock B450 gaming k4 - Gskill Ripjaws 2x8GB @3200mhz CL16 - Be Quiet Straight Power E11 650w - Fractal Meshify C - EK-Kit S240 - NB eLoop 120mm PWM - Be Quiet Shadow Wings 140mm 1000rpm - Bitfenix Spectre LED PWM 120mm - Samsung 250GB 860 Evo - Seagate Barracuda 2TB
Peripherals:  Acer XF270HBbmiiprzx 144hz 1080p TN - CM Storm Quickfire TK - Coolermaster MK750 - CM Storm Reaper - Logitech G303 - Logitech G502 - Logitech G603
Audio:  Hyperx Cloud Stinger - Samson SR850 - Trust Screamer - Creative Gigaworks T20 II
https://linustechtips.com/topic/1129950-toss-it-or-keep-it/#findComment-13096018
