nvidia graphics driver stuck on checking system compatibility
the installer is stuck on checking system compatibility like forever, im trying to install drivers for my 1050ti on laptop, i uninstalled drivers through ddu because my graphics card was crashing and now i cant get the drivers to install, help please ASAPP
mine does this when i forget to press yes or accept to the windows notification asking if it's okay for the app to perform changes to important data.
It doesn't always pop up automatically but just shows in your task bar as another application.
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
Have you tried restarting the system? Also try this driver: https://www.nvidia.com/Download/driverResults.aspx/154343/en-us
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
On 11/30/2019 at 7:22 AM, navnxxt said:
whats the difference ?
do it. its studio driver.. enhanced stability
Gaming PC:
Linux PC:
Gaming PC:
Linux PC:
  • 3 years later...
Came across this post when dealing with the same issue with a 2080 Super when upgrading to any recent update. After the window pops up that gets stuck on checking compatibility requirements I was able to get it to go past by opening another instance of the installer from the extracted folder. As flashiling said, this usually happens when an admin prompt is missed. It seems to just not be opening the prompt after running the installer when it completes the extraction. So while the initial installer is still running and "stuck" just run another installer and you will get an admin prompt and a second installer will run and actually work.
