Best adapter to use for converting To VGA from GTX 1060?
DVI to VGA if it has DVI-I. Otherwise, HDMI to VGA.
But if the monitor only supports VGA you're better off replacing it.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
I would recommend a Displayport to VGA adapter above an HDMI to VGA adapter, because Displayport carries a native analog signal and HDMI doesn't. Also the GTX 1060 has 3 Displayport ports and 1 HDMI port which makes it better to connect via Displayport since you have more of them :)
I have good experience with these: https://www.amazon.com/StarTech-com-DP2VGA2-DisplayPort-Adapter-Converter-Black/dp/B003V4TV8O.
But these are quite expensive and you can get others for cheaper like this one https://www.amazon.com/dp/B00Z08TZNU. I don't have any personal experience with this one, but it should be fine according to the reviews.
If you ask for links please tell what country you will be ordering from. This makes it easier to supply links with accurate pricing.
