How will my build run?
Go to solution Solved by Hugh54321,
downgrade the CPU to a 2600 and get a really good GPU with the price difference. Watch this Jays2cents video. I got the 2600 and a 5700XT. GPU is running at 100% and CPU is running at less than 50% on these games: RDR2 - low graphics, fallout 4 - ultra/high, Doom - ultra/high. 2600 is super cheap right now and I see no reason to get anything more powerful when pairing with a mid-tier GPU.
I'm doing this build (first build) and I need to know how will this pc will perform before I buy the parts, if anyone can help me I will very kindly appreciate it :)
the specs are
  • 1TB HDD + 256gb SSD
  • Operating SystemWindows 10
  • RAM8 GB DDR4 2666Mhz
  • Processor Speed3.6GHz (32M cache, up to 4.4GHz)
  • Processor ModelAMD 8-Core RYZEN 7 3700X CPU, 3.6GHz
  • Graphics CardNVIDIA GeForce GTX 1650 4GB
https://linustechtips.com/topic/1127688-how-will-my-build-run/
depends on what you do with it... but I feel like this is a prebuilt system, not a custom machine
Desktop benching:
https://linustechtips.com/topic/1127688-how-will-my-build-run/#findComment-13077728
what will you do with it? because in my opinion, you can go down to a 3600 and just get a better GPU
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1127688-how-will-my-build-run/#findComment-13077729
15 hours ago, OlympicAssEater said:
Motherboard probably a low end one.
oh right, he didnt mention that part, the psu as well.
CURRENT PC SPECS
https://linustechtips.com/topic/1127688-how-will-my-build-run/#findComment-13077762
https://linustechtips.com/topic/1127688-how-will-my-build-run/#findComment-13077771
