Quick question about ejecting USB devices
Update: it's a bit embarrassing but also not really my fault... Actually a Windows update turned off "receive messages from other senders"... I should have checked this but I was absolutely 100% certain I had this turned on - and I don't expect an Update to continously reset my settings, even though that seems to be normal Windows 10 behavior.
And for the record: only now it ejects / unmounts my USB drives correctly, before my external hard-drive would always make a high pitched, screeching sound when I unplugged it, even after clicking "remove this device safely" which as I already tried to explain does absolutely nothing by itself and is very dangerous for the data on the drive, it still needs the "device can now be removed safely" message to actually work.
Welcome to Windows and hopefully this helps someone with similar issues.
