I currently have a computer I am selling because it is overkill for what I do with it. If your curious it has these specs:
Ryzen 7 2700x
x470 Motherboard
32GB of DDR4 RAM rated and running at 3000.
250GB MX500 SSD
8GB RX580
Prices seem good for computer hardware right now, but that wont always be the case, so I am thinking about just building a different PC that is powerful enough for what I plan to use it for without reaching too deep into my pockets.
The most demanding game I play is Fallout 4 (unmodded and no add ons) at 1440p set to ultra. Otherwise I think the next most demanding game I play is Skyrim. I do not play any other triple A games; I mostly play indie games. I want a system that can play those 2 games at 1440p at or above 45fps while streaming them at 1080p at 30fps or better.
I also read that for streaming, 6 cores on a processor is recommended, 8 cores is better, but would that be the case for either of those games, or should I be able to comfortably hit my goals with a 6 core processor such as the Ryzen 5 2600?
Here is what I am considering:
Ryzen 7 2700
B450 Motherboard
16GB RAM at 3000
1TB Crucial P1 SSD
RX 580 8GB
The next most demanding game I will likely play on this PC /might/ be the next Elderscrolls game, which looks like it will not come out for at least a few more years, so I m not worried about "future proofing" it.
Any suggestions one way or another, such as "RX 590 is a bit overkill", because that would save me money. Thanks in advanced.
I already have a buyer for my current system for $1000, I already have the SSD and another case for my new build. Doing research on Ebay, I have found that I can purchase everything else for about $500.
https://linustechtips.com/topic/1126352-going-to-make-a-stream-machine/
Why are you selling a PC with a faster CPU and more RAM and then buying a new PC with a slightly slower CPU, half the RAM, and a slightly faster GPU?
This makes zero sense. Just stick with what you have.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
Because it is likely overkill for what I use it for and if I sell it and build a system that is better tailored for my needs, I make a profit in the end.
You will lose money selling your old gear and buying new and inferior gear.
If anything -- sell part of that RAM kit if it's a 4 dimm kit.  If it's 2 dimm kit then sell the entire kit and buy another.  Though that's also not ideal.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
You won't profit.  Look up the items you have now on eBay and you'll see that used items are usually selling for less than what you'd pay new.
No you do not make a profit in the end lmao. You lose money, time, and if your local classified buyers are anything like mine, you lose your sanity.
Don't. Just don't. Stick with what you have. You want to "downgrade" but you're doing a sidegrade.
SPECS:
Doesn't worth it at all,You will lose money with the result of an inferior system
and the RX 590 is just an overclocked RX 580.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
I likely should have mentioned this, but I already have a buyer for my current system for $1000, I already have the SSD and another case for my new build. Doing research on Ebay, I have found that I can purchase everything else for about $500.
I likely should have mentioned this, but I already have a buyer for my current system for $1000 and I already have the SSD and another case for my new build. Doing research on Ebay, I have found that I can purchase everything else for about $500.
well that guy may be kinda overpaying. not sure why you would want to get an rx590 which is just an overclocked rx580. don't commit till you get cash from buyer.
Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset)  /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro
Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry  /// External Drives: 500GB Samsung T5 SSD (Working Drive)
Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro  /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid
Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI  /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro
Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor  /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home
Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver)  /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey
Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV,  Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it
Well if you've found a sucker then you're golden, but double-check that you can buy EVERYTHING again for a new system without being unhappy with the result.  I'm talking fans, cables, Windows license, etc.
If you only make a few dollars off of that sucker and end up with an inferior system then I don't think you're gonna be happy with the hassle of it all.
Fair point, but I am more interested in knowing if this what I am planing will be up to the task I am aiming for. Also I have taken your and another commentator's advice on the RX590, so I will change my post to reflect that; thank you.
also if you are gaming alot, i believe the resale value of a ryzen 2700 and a ryzen 3600 is around the same price. the ryzen 3600 will perform better in games.
Oh believe me, I got more than enough parts lying around where I don't need to worry about cables, fans, ect. With my estimate, I am looking to make $400 to $500. Also, while it is inferior in hardware for the most part, I want to know, with my usage, would I notice a difference when playing and streaming? I am one of those people that does not really notice much of a difference after I hit 45fps.
Then it's worth to sell.
Wait until you get the money and buy this (The 1660 Super is better and cost the same as the RX 590):
PCPartPicker Part List
Type Item Price
CPU AMD Ryzen 5 3600 3.6 GHz 6-Core Processor $194.00 @ Amazon
Motherboard MSI B450 TOMAHAWK MAX ATX AM4 Motherboard $114.99 @ Amazon
Memory G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory $69.99 @ Newegg
Video Card EVGA GeForce GTX 1660 Super 6 GB SC Ultra Black Video Card $219.99 @ Newegg
Power Supply Rosewill Capstone 650 W 80+ Gold Certified Semi-modular ATX Power Supply $59.99 @ Newegg
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $678.96
  Mail-in rebates -$20.00
  Total $658.96
  Generated by PCPartPicker 2019-11-22 10:53 EST-0500
Wait until you get the money and buy this:
Type Item Price
  Total $658.96
Thank you, but here is what I am looking at:
CPU: $160  https://www.ebay.com/itm/AMD-RYZEN-7-2700-8-Core-3-2-GHz-4-1-GHz-Max-Socket-AM4-65W-Desktop-Processor/193191420735?epid=12028660860&hash=item2cfb1b233f%3Ag%3Az6IAAOSwai5dv3MZ&LH_BIN=1
Motherboard: $60  https://www.ebay.com/itm/GIGABYTE-B450M-DS3H-AM4-AMD-B450-SATA-6Gb-s-USB-3-1-HDMI-Micro-ATX-AMD-Motherboa/292689775281?epid=27032161417&hash=item4425ab8ab1%3Ag%3Afa0AAOSwfBFber0C&LH_BIN=1
RAM: $50  https://www.newegg.com/g-skill-16gb-288-pin-ddr4-sdram/p/N82E16820232417?Item=N82E16820232417&nm_mc=AFC-RAN-COM&cm_mmc=AFC-RAN-COM&utm_medium=affiliates&utm_source=afc-PCPartPicker&AFFID=2558510&AFFNAME=PCPartPicker&ACRID=1&ASID=https%3a%2f%2fpcpartpicker.com%2fproduct%2fFNprxr%2fgskill-aegis-16gb-2-x-8gb-ddr4-3000-memory-f43000c16d16gisb&ranMID=44583&ranEAID=2558510&ranSiteID=8BacdVP0GFs-W6fhCmqY3GRJDmvlcpdlMw
GPU: $120  https://www.ebay.com/itm/XFX-AMD-Radeon-RX-580-Black-Edition-8GB-OC-WORKS-GREAT/184045434124?epid=14021692422&hash=item2ad9f6750c%3Ag%3AVeIAAOSwAfVdsDwA&LH_BIN=1
PSU: Up in the air right now, but I expect to pay about $50
The total would be about $450. Now with your suggestions, it does raise another question. Would a 6 core processor do what I am aiming for, or should I stick with an 8 core?
You have to consider, 4-5 years from now you'll most likely have a woefully underpowered system whereas if you keep your current PC, it may still be adequate. Doesn't make much sense, especially since you're going to lose money selling it and buying new lesser components.
This is a low quality motherboard i recommend to avoid.
2 minutes ago, Ykcud said:
At that price you can get this:
Type Item Price
Memory Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 Memory $54.99 @ Newegg
  Total $54.99
  Generated by PCPartPicker 2019-11-22 11:13 EST-0500
This one is pretty good:
Type Item Price
Power Supply Rosewill Capstone 550 W 80+ Gold Certified Semi-modular ATX Power Supply $54.89 @ Amazon
  Total $54.89
  Generated by PCPartPicker 2019-11-22 11:14 EST-0500
Streaming Skyrim and Fallout 4 is a piece of cake for the Ryzen 5 3600,
But for a more demanding games 8 cores will make a difference.
The 3600 performs better in gaming than the 2700 though.
