CPU:- Intel Core i7 4960X
Motherboard:- Rampage IV Black Extreme Edition
RAM:- Dominator Platinum 64GB (2400)
GPU:- GTX 780 Ti Classified KingPin Edition
Case:- Phantom 820
PSU:- Ax1200i
CPU/GPU Cooler Components:-
Pump:- Swiftech MCP655 Variable Speed 12v Water Pump w/ G1/4 Thread Ports (Perfectly Tapped)
Fans:- 5 Scythe GentleTyphoon Fans. (3 for top Radiator & 2 for the bottom Radiator.)
Reservoir:- BitsPower Eater Tank Z-Multi 150 Inline Reservoir - Clear (BP-WTZM150AC-CL)
Radiators:- 1 Alphacool NexXxoS Monsta 360 (Top) 1 Alphacool NexXxoS Monsta 240 (Bottom)
Tubing:- PrimoFlex Advanced LRT 3/8in. x 5/8. Tubing (10Ft Pack) - Onyx Black
Fittings:- BitsPower G1/4 Thread 3/8" ID x 5/8" OD Compression Fitting - Black Sparkle (BP-BSCPF-CC3)(I don't really know much I need of these but if anybody could comment down below and tell me how much I need of these Compressions that would be great.)
Coolants:- Mayhems Pastel Coolant Concentrate - 250mL - Pure Black (Or might just go with regular Distilled Water but if someone could comment telling me if this Mayhems Coolant is good just like Distilled Water.)
WaterBlock:- RayStorm CPU WaterBlock (Intel) (I don't really know other WaterBlocks so I choose this one but if there is another better one please comment down below.)
Razor GTX Titan / 780 / 780Ti GPU [ http://www.xs-pc.com/waterblocks-gpu/razor-gtx-titan-780-780ti ](Same goes for the GPU I really don't know good manufactures but if you guys know a better one please comment down below)
Thanks in advance for anybody who will/has helped me.
Cheese
https://linustechtips.com/topic/112580-will-this-custom-loop-work/
boop
please take no offence from this, but judging from your other posts this sounds like your first build please dont go rushing in allot of things can go wrong from lack of experience (heck im thinking about making on but i dont think im up to it). but just give yourself some more time to get more skills and understanding before you try doing all the fancy stuff
Specs
First of all I would rump the platinum ram for some other cheaper 2400mhz RAM.... its the exact same stuff.
Dont use mayhems pastel with primoflex LRT. it turns the pipes green and stuff can form due to the plasticizer in the LRT.
Try to stick to a full EKWB (EK) full loop as they are the best at everything (fittings/pumps/blocks)
Quack 🦆
I've been building computers since I was 15. I know what I'm doing I'm just new at this water cooling stuff...
Cheese
So should I just go with Distilled Water?
Cheese
This issue has been solved with the newer generation from primoflex.
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
I don't get it should I stay with that Mayhem Water thingy or Distilled Water?
Mayhems pastel with clear tubing, or distilled water with colored tubing. Your choice. Distilled water is best for the longevity of the loop, and your components. Remember to add a biocide if you go with distilled water. Maybe a chunk of silver coil would be good.
Main Rig
Phone
I can't go with Colored Tubing + Colored Water? Why not? :'(..
Cheese
People are saying I can't do Colored Tubing + Mayham Paste thingy.
you can, it's kind of pointless since you already have colored tubing so what's the point in colored coolant, the only thing it would be noticeable in is the res.
Error: 410
Exactly my point I want the Reservoir to be black. And I accidentally made your post the solved answer (Unsolved it though lol)
Cheese
use window film/tint (since you are looking for a blackout) for the res tube to color
the contents. primo and others tint the acrylic to do the same. this way if you chose
another scheme, rip the film off, clean the acrylic and use what other color/coolant you
wish.
to be honest, blackout h2o builds get to be lost and do not seem to translate well in
looks. always need accenting colors and contrast to make the loop look lively.
