I'm looking to build a gaming rig for AAA games at 2k, also capable of running [some] 3d printing cad sofware, and web browsing using AMD ryzen. Not interested in RGB but I wouldn't refuse a good piece if it had.
because i'm new to bulding i need some help with the quality/prefomance/price of the components i'm going to use i have a rough idea but need help ironing it out.
First i'm from Canada
buget 2500 to 3500
CPU: Ryzen 7 AM4 3700X (this was recommended to me but would I need to go higher?)
Motherboard: Asus Prime x570-P Mobo
Memory: TridentZ 32GB 3200Mhz CL16 gskill
PSU: Corsair TX850W gold
GPU: EVGA 2070 Super Black Gaming 8GB
M.2 SSD: AData XPg SX8200 1TB
WD Black 2TB HDD
Case: Corsair Obisidian 750D (optional - I like this one but I'm not too picky, but I do want a full-size case)
Monitor: still looking - any recommondations? High res, 2k gaming, 24-32"
I have a mouse and keyboard
None of these parts are set in stone so if you have other recommondations I'd love to hear them.
https://linustechtips.com/topic/1124953-help-needed-on-gaming-build/
You do not need that huge wattage. A fine-tuned 2070Super is roughly 180-185 watts. A good 550w unit would be sufficient, a 650w would be even suitable for oc-ing.
And get a CPU cooler :) And if you have access to Crucial Ballistix Sport LT 2x8 GB 3200Mhz CL16 memories with micron-E die. a Must have! Friend of mine OC-d them to 3600mhz with cl16 CAS latency, on 2nd gen ryzen5. And also tested them with intel 9700k&Gigabyte Z390 Aorus Pro mobo, the RAMs OC-d to 3600Mhz CL14& 3733Mhz cl16. (well, he has the 3000Mhz CL15 model, but, I think those are the same as 3200Mhz CL16-s)
Life is really challenging. I don't always suceed: )
