Ram speed question
Go to solution Solved by Jurrunio,
1 minute ago, ImBumi said:
I can't remember if I set it to 3000Mhz or 32Mhz. Is there a way to check?
Sorry, it's been a while since i meddled with my system settings that i lost touch.
It is currently at 3000MHz, just double DRAM frequency
It's running at 3000/2933Mhz, so if you remember setting it to that; you're good!
The first screenshot shows the info you're looking for.
NB frequency * 2 = RAM speed.
https://linustechtips.com/topic/1124939-ram-speed-question/#findComment-13055906
not exactly, since the kit is rated for 3200MHz but you're running 3000MHz
Desktop benching:
https://linustechtips.com/topic/1124939-ram-speed-question/#findComment-13055916
Desktop benching:
https://linustechtips.com/topic/1124939-ram-speed-question/#findComment-13055926
Just now, ImBumi said:
So everything should be normal then?
everything else, just not the frequency.
Desktop benching:
https://linustechtips.com/topic/1124939-ram-speed-question/#findComment-13055938
