for homework at school i need to make program which will calculate and decide if number set by user is prime number.
i thought about doing it with an it sentence but it wolud have to go something like this:
if (number%everything betwen number and 1==0) {
cout << "number isn't prime"
}else {
number is prime
and my actual question is if there exist a command that can automaticaly devides the number with evrey number betwen?
i need to do it in c++
pls help.
tnx
https://linustechtips.com/topic/1124530-need-some-help/
pls help.
tnx
We won't do your homework for you but if you have a specific question ask away. Remember to quote us so we get a notification.
sudo chmod -R 000 /*
https://linustechtips.com/topic/1124530-need-some-help/#findComment-13052863
}else {
number is prime
https://linustechtips.com/topic/1124530-need-some-help/#findComment-13052891
No, but you could use a for loop. Programming isn't just about finding premade functions that do exactly what you need.
https://linustechtips.com/topic/1124530-need-some-help/#findComment-13052894
