Think of a heatpipe that has the dimension of a trackpad on a laptop with fins on one side, thing to cool on the other. Vapor chamber is just used for spreading heat out to the fins.
Desktop benching:
https://linustechtips.com/topic/1123845-vapor-chamber-cooler/#findComment-13048127
Image result for vapor chamber graphic
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
https://linustechtips.com/topic/1123845-vapor-chamber-cooler/#findComment-13048129
I think of them as flattened heat pipes
https://linustechtips.com/topic/1123845-vapor-chamber-cooler/#findComment-13048139
