I'm looking to build a new compact gaming rig and the biggest problem i'm running into is heat. The case i had my eye on was the Cooler Master Elite 120, this is a nearly perfect size and looks good too. The only problem is it does not have good ventilation/fan placement and would not be able to handle gaming for very long without parts overheating.
I need suggestions for the most well ventilated/heat dispersing small form factor case. I plan on running an i5-4570 and gtx 660 for reference in heat build up but i dont want suggestions for the cpu and gpu please, just the case.
Project Zues:
GPU: ASUS GTX 670 Direct CU II | CPU: Intel i7 3820 @3.6 GHz | CPU Cooler: Cooler Master Hyper 212 Evo | MOBO: ASUS Sabertooth X79 | RAM: G. Skill Ripjaw Series 2x4Gb | PSU: Corsair HX 750W | Case: NZXT Phantom Full Tower
https://linustechtips.com/topic/112382-best-small-form-factor-case/
Bitfenix you B'tch! Couldn't control myself by looking at elite 120.It looks like an HTPC case.
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
Well for Mini-ITX the Hadron Air is very good. It is extremely small and accommodates up to a 780 ti. The bitfenix Prodigy is the second go to choice for mini itx also but it does not come with an 80+ gold PSU or a PSU at all.
"If you do not take your failures seriously you will continue to fail"
You could go with the 250D
| i5-4670k @ 4.2Ghz | Corsair H100i | Gigabyte Z87X-UD4H | Corsair Vengeance Pro 8GB | ASUS Geforce GTX 770 |
| Samsung 840 Pro 128GB | WD Black 1TB | Corsair AX760 | Fractal Design Define R4 Black w/ Window | Corsair AF140 x2 |
| Windows 8.1 | ASUS 23" 1080p monitor | CM Storm Quickfire Stealth- MX Blue | Logitech G9x | Logitech G930 |
