My brother wants to get a PC for a friend of his and wants some help, I was just wondering if there is anything that I'm missing in this or that would be better, I have all the components that are marked at 0.00 on the Pc Part Picker and he has a budget of 500 dollars for more parts. I don't plan on OC but I wanted the CPU to not get hot. The purpose of the PC is to play videos games such as 7 days to die.
PCPartPicker Part List
Type Item Price
CPU AMD FX-8350 4 GHz 8-Core Processor Purchased For $0.00
CPU Cooler Corsair H60 (2018) 57.2 CFM Liquid CPU Cooler $79.98 @ Amazon
Motherboard Gigabyte GA-970A-DS3P ATX AM3+ Motherboard Purchased For $0.00
Memory G.Skill Ripjaws X Series 8 GB (2 x 4 GB) DDR3-1333 Memory Purchased For $0.00
Storage Samsung 860 QVO 1 TB 2.5" Solid State Drive $109.99 @ Amazon
Video Card MSI GeForce GTX 1650 4 GB GAMING X Video Card $159.99 @ Newegg
Case Aerocool Cylon ATX Mid Tower Case $49.99 @ Amazon
Power Supply EVGA 430 W 80+ Certified ATX Power Supply Purchased For $0.00
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $414.95
  Mail-in rebates -$15.00
  Total $399.95
  Generated by PCPartPicker 2019-11-14 12:56 EST-0500
https://linustechtips.com/topic/1123641-howdy-need-yalls-help-again/
Are you trolling him or seeking revenge?
Desktop benching:
You can get a much better graphics card for cheaper, and also a much better CPU cooler. With the money you saved you can afford a halfway decent power supply to replace your current unit.
Primary PC:
Better SSD for $2 less:
PCPartPicker Part List: https://pcpartpicker.com/list/K7g27T
CPU: AMD FX-8350 4 GHz 8-Core Processor  (Purchased For $0.00)
CPU Cooler: ARCTIC Freezer Xtreme Rev.2 Fluid Dynamic Bearing CPU Cooler  ($35.99 @ Amazon)
Motherboard: Gigabyte GA-970A-DS3P ATX AM3+ Motherboard  (Purchased For $0.00)
Memory: G.Skill Ripjaws X Series 8 GB (2 x 4 GB) DDR3-1333 Memory  (Purchased For $0.00)
Storage: Crucial MX500 1 TB 2.5" Solid State Drive  ($107.50 @ Adorama)
Video Card: ASRock Radeon RX 570 4 GB Phantom Gaming D Video Card  ($129.99 @ Newegg)
Case: Aerocool Cylon ATX Mid Tower Case  ($49.99 @ Amazon)
Power Supply: EVGA 430 W 80+ Certified ATX Power Supply  (Purchased For $0.00)
Total: $323.47
Generated by PCPartPicker 2019-11-14 13:07 EST-0500
MX500 competes with the 860 Evo, IIRC the QVO isn't the best of drives.
Main PC
CPU: i5 12600KF
Cooler: Noctua NH-L12S
Motherboard: ASRock Z690 ITX/ax
RAM: 2x16GB 3600Mhz DDR4
GPU: Intel ARC A770 16GB LE
Storage: 1TB MP34 + 2TB P41 + 2x 1TB MX500
ODD: LG WH14NS40
PSU: EVGA 850W GM
Case: Silverstone Sugo 14
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 15" M3 MacBook Air (work) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, flash, running Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2022 Kawasaki KLR650
Is there something I should be looking for particular with the PSU? The Current system specs are well within the PSU specs?
6 minutes ago, Terry_B said:
Is there something I'm missing? Can I build I better gaming with only 500?
easily
Quote
wattage isn't the only factor. A PSU can deliver enough power and still be crap.
Primary PC:
1 minute ago, Fasauceome said:
Hey Bud thanks for the help, anything I should do w/ my old parts laying around?
there aren't many uses in gaming for the old FX line, but if you need a plex server or something, or maybe a home theater PC you can disable half the cores and slap a super cheap graphics card in there for some basic web browsing or something.
That or donate them to a very desperate gamer in need. That board along with like $200 makes a good ultra budget machine for someone scraping together a PC.
Primary PC:
If you want to know something to laugh at my native 14 year old self bought that at full price (110 dollars) when it was going on ebay for 30.
im sad in myself thanks for your helps guys
just consider it giving AMD a booster shot to help develop Ryzen, that's all.
Primary PC:
Had to make some adjustments because brother needs it within 6 days
just making sure this is still ok atleast. Also Mircocenter is nearby house will look on their site to see if any compents are cheaper
Looks good to me, would look for used rx570 8gb model on ebay, but if he needs the parts fast, go with those
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
Actually now that I think of it, the CPU and board and memory can stay if upgradability is the utmost concern. Just a CPU + board + RAM swap will get it up to mainstream gaming rig status, while starting with Ryzen at first means using weaker GPU hence not fairing so well over time.
Desktop benching:
25 minutes ago, Terry_B said:
Even the cheapest b450 board would be better
Primary PC:
