Need help with wiring my GPU
Solved by Spotty,
You can use this handy compatibility chart on Corsair's website to see what type of cables are compatible with your power supply.
https://www.corsair.com/ww/en/psu-cable-compatibility
For the Corsair CSM PCIe cables it uses Type 3 Corsair cables, however Type 4 is also compatible. Both Type 3 and Type 4 PCIe cables are available on Corsair's website, as well as third party sites such as Amazon. The SKU for the pigtail (two 6+2pin connectors on the end of one cable) Type 3 connector is CP-8920114. The Type 4 cable is CP-8920143. Should cost about $5 per cable.
You can also find fancy custom coloured sleeved cables, but they will be more expensive around $20+ each.
