Isn't it simpler to just get a console at that price point?
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
https://linustechtips.com/topic/1122503-please-help/#findComment-13036991
Black Friday, grab an Xbox One for $150, done.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1122503-please-help/#findComment-13037020
9 hours ago, 2011PCGuy said:
Hey, I'm currently looking for a computer for my little brother for around 250-300 usd for minecraft. He needs wireless networking too.
If he wants a desktop, go with a used or refurbished dell optiplex, and if you think u need more graphics, a $20 gpu from microcenter or amazon will be fine.
If he wants a laptop, i would recommend this one: link
i like trains 🙂
https://linustechtips.com/topic/1122503-please-help/#findComment-13037028
You didn't mention if you needed peripherals like a keyboard and mouse and a monitor so I didn't add it.
Here's a bare minimum build just for Minecraft. This one is running the graphics on the AMD's APU but if you want a more capable GPU we can probably add a cheap one.
The deep blue sky is infinitely high and crystal clear.
私はオタクではありません。
https://linustechtips.com/topic/1122503-please-help/#findComment-13041697
I mean peripherals will be needed. Don't have any spare peripherals if any thing Intel may be a bit of a better choice cause old ones are cheaper and ddr4-2400 will work plz thanks for the help currently
https://linustechtips.com/topic/1122503-please-help/#findComment-13049309
Something with a real upgrade path.
You don't want to lock yourself in without a proper upgrade path for the CPU. This build list gives you some room to get a cheap monitor off eBay and a used mouse and keyboard as well.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1122503-please-help/#findComment-13049340
