Random Crashing without code, USB randomly stops working
Solved by Calamity1911,
Well, I gave up with troubleshooting as running checkdisk and SFC didn't do anything, so I backed up a couple of my games and COMPLETELY wiped ALL of my drives. I've been using it for a few hours with no issues.
I made a multiboot installer with a few Linux distros on it, as well as a Windows installer. I backed everything up from a live instance of a distro on that drive.
I then booted into the windows installer, and went to troubleshooting and chose the command line option and used diskpart to wipe all of my drives. I then rebooted the installer and installed as I normally would.
