using pc without integrated graphics
Solved by mariushm,
All video cards manufactured have a standard minimal functionality, which makes it possible for you to go in BIOS and change settings, or use the video card in very basic modes (no acceleration, everything super basic, limited number of colors and resolutions in some cases)
Windows has a driver that supports this very basic functionality, so if it can't find and install the actual drivers, it will install this very basic driver that works with any video card, that's what "generic vga adapter" means
