As stated above pc is in a boot loop, i was watching leds on the motherboard and when it is trying to turn on it goes, CPU led turns on and off, VGA led turns on and off, sometimes pc shutsdown after the VGA led turns on, but more often then not PC shutsdown after BOOT led turns on, i just don't understand why DRAM led doesn't turn on, tried with 2 different sticks running at different speeds in different DIMM slots and still RAM led doesnt light up, does that suggest that motherboard is dead or both RAM sticks are faulty?
CPU: Ryzen 5 2600
GPU: RX 570
PSU: Corsair VS450,450 W
Motherboard: MSI B450 Tomahawk
RAM: 1x Kingston value 2133 mhz, 1x G Skill Aegis 3000 Mhz
https://linustechtips.com/topic/1121657-pc-boot-loop-problem/
CPU: Ryzen 5 2600
GPU: RX 570
Just built? Check cables. Clear cmos./take out battery for 5 min. And try RAM sticks in 2nd slot (A2) one at the time.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1121657-pc-boot-loop-problem/#findComment-13030706
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1121657-pc-boot-loop-problem/#findComment-13030708
