On 11/6/2019 at 10:29 AM, Yellowpanda said:
Hey guys, I was going to try to paint the red fan plastic of the MSi  GTX 1080 Ti Gaming X. What kind of paint and paint procedure should I use on the red plastic?
Any help would be greatly appreciated.
Thanks
You can use regular hardware store spray paint long as the parts are properly preped and primed for adhesion purposes. For the best color selection and color vibrancy automotive or arstists spray paint will be your best option. You will need to take apart the shroud and separate the pieces to properly paint.
