Need help with ram issues 1 stick works alone and so does the other but not both at the same time.
Go to solution Solved by Kevin Sherif,
Fixed it flashed back my motherboard to the older working bios with 2 sticks and now it works
Specs:
I7-7700 (non k)
Ram:
   1:8gb ddr4 2666mhz crucial ballistix
   1:8gb ddr4 2400mhz kingston generic ram
Gpu:Gtx 1080 ti xtreme aorus
Storage:1tb Seagate barracuda steam library and 240 gb kingston sa400 SSD
Mobo: Asrock b250m pro4 1.50 bios updated to 2.50 Supports a max of 2400mhz
Psu: Gigabyte p650w
So I was updating my bios and it was at 60% I left and came back the screen was black computer. shut off the computer manually and every time I open it i get a black screen but the fans keep spinning.
Next day go to a computer repair shop as my motherboard support didn't answer the BIOS chip was not working so the engineer at the shop removed it and programmed another one and soldered it to the motherboard and boom
my computer was working again, when I went back home I added my other ram stick that I removed and my pc screen won't load either the computer keeps rebooting or it boots up and then doesn't do anything .
My computer boots up with 1 stick in any slot the 2666 or the 2400 but not both at the same time I tried cleaning the ram contacts using canned air for the motherboard ram slots and re seating the cpu and the cooler making sure it has good contact but still i'm bound to 8 gb of ram
My computer used to boot up with both the sticks in any slots whether running in dual channel or single
►Specs
• Processor - Intel Core I7-7700 4.0 GHz
• Graphics Card - Gigabyte Gtx 1080 ti aorus xtreme
• RAM - 8 GB Ballistix Tactical DDR4 2666MHz
• Ram - 8 GB Kingston DDR4 2400MHz
• HDD - 1TB WD 7200
• SSD - 240 gb Kingston (SA400)
• PSU - Gigabyte P650B
►Peripherals
• Monitor #1 Samsung Curved 144hz
• Monitor #2 Asus VP228
• Microphone - Blue Yeti Microphone
• Keyboard - Gigabyte K83 Cherry Mx Red
• Mouse - Logitech G403
• MousePad - HyperX speed L, G440 Soft pad L
• HyperX Cloud Pro
Perhaps that ‘engineer’ fucked your board.
on a second note; what slots are you using ?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
I tried using the first and 3rd slots then the second and fourth slots but now im using 1 stick on the first slot
Can it be that the newer bios doesn't like the different ram sticks with the different speeds?
►Specs
• HDD - 1TB WD 7200
►Peripherals
• HyperX Cloud Pro
Speed shouldn’t matter. Both sticks will run at the lowest rated speed.
Have you tried every slot with a single stick ?
Yes
►Specs
• HDD - 1TB WD 7200
►Peripherals
• HyperX Cloud Pro
Somebady help me :*(
►Specs
• HDD - 1TB WD 7200
►Peripherals
• HyperX Cloud Pro
Could it be the newer bios is conflicting with the 2 sticks of ram or I need certain settings to make them work?
►Specs
• HDD - 1TB WD 7200
►Peripherals
• HyperX Cloud Pro
  • 2 weeks later...
►Specs
• HDD - 1TB WD 7200
►Peripherals
• HyperX Cloud Pro
Heh, that's interesting,  BIOS update can and sometimes will break RAM compatibility...
I mean that's not too surprising,  just shows one of the bigger flaws of updates in general,  they aren't always a good thing.
At least it's possible to flash back a BIOS so no real damage was done (except the soldering / repair costs)
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
