Msi afterburner fps on screen help.
Solved by Ichoumaz,
1 minute ago, NotABigGamer said:does it only work for steam games?
no, it should work for every game, but maybe it doesnt work with certain games, depends on the compatibility, i'm gonna re test destiny 2 and see if it works with it.
now go to the on screen display window ->Toggle OSD and setup your hotkey, and once you are ingame, use your hotkey and it should come up.
Featured Topics
wolfgangam ·
Posted in Windows1 -
1
2
Joseph_Stalin ·
Posted in General Discussion4 -
Evan37 ·
Posted in New Builds and Planning5 -
IlanMS ·
Posted in Peripherals9 -
Frossty ·
Posted in Graphics Cards9
