So I've never had any dealings with amd gpus, but I went out on a limb and bought an rx5700xt because it seemed to have comparable performance to a 2070 super. My question: is there anything in particular I should know before installing?
Current rig:
Ryzen 1600
EVGA 600 watt psu
16gig Corsair vengeance 3000
Rx 5700xt
https://linustechtips.com/topic/1120113-plz-help-is-noob/
EVGA doesnt make any 600w PSU worth recommending, so....
5700XT is performance-wise squished between the 2070 and 2070 Super
if it's not a blower card it should at least not come with heat issues. It's up to the case airflow afterwards
Desktop benching:
https://linustechtips.com/topic/1120113-plz-help-is-noob/#findComment-13017606
8 minutes ago, Xiee said:
Your processor might be a bottleneck if you try to play above 1440p resolution.
why would the CPU cause trouble when there are more pixels on the screen? The GPU is drawing the frames
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1120113-plz-help-is-noob/#findComment-13017611
I forgot to add that it also depends on how many frames you're trying to push on the game. The processor might not be able to keep up with a higher GPU. I'm saying this from experience.
I have a Ryzen 1600. When I was testing out a 2070 for a friend, I noticed how my processor was struggling to keep up when I played Rainbow Six Siege on a 27 Inch monitor capable of 144hz freesync at 1440p. Noticed some stuttering and other minor things but the game was still playable. At 1080p, I had no problems. I was playing on custom settings from high - ultra.
My friend on the other hand had a Ryzen 2700X and he wasn't having any problems at 1440p@144hz..
The deep blue sky is infinitely high and crystal clear.
私はオタクではありません。
https://linustechtips.com/topic/1120113-plz-help-is-noob/#findComment-13017629
I too agree with calling BS on this notion.
Consider the fact that when review websites want to show the difference in a range of CPUs, they run games at 1080p on lower settings with a very high-end graphics card in order to force-CPU bottlenecks.  1440p and 4k resolution are the great equalizer in taking the stress to the GPU and hiding any bottleneck from hitting the CPU and making it a factor.
https://linustechtips.com/topic/1120113-plz-help-is-noob/#findComment-13017638
Like I said on my post above, I'm talking from experience.
I did say "might" as I do know not everyone will experience what I have. I'm not saying it's a definite issue.
私はオタクではありません。
https://linustechtips.com/topic/1120113-plz-help-is-noob/#findComment-13017641
You didn't say what quality settings you were running or that you made sure to use the same video driver, but since your testing was in-exact that's mostly a factor of potential RAM difference, and other discrepancies, in addition to possibly not comparing apples to apples.  Also it's 1 sample, and doesn't speak for the overall relationship between CPU's mattering in games, and chasing high FPS.
https://linustechtips.com/topic/1120113-plz-help-is-noob/#findComment-13017643
1 minute ago, LogicWeasel said:
You didn't say what quality settings you were running, but since your testing was in-exact that's mostly a factor of potential RAM and other discrepancies, in addition to possibly not comparing apples to apples.  Also it's 1 sample, and doesn't speak for the overall relationship between CPU's mattering in games, and chasing high FPS.
I'm sorry for not including all the info.
I was on 16gb RAM Gskill Ripjaws (3200) and on custom settings (high to ultra). Processor isn't overclocked. I tested this on a few games other than Rainbow Six Siege which are Assassin's Creed Odessy, World of Tanks and Overwatch. I noticed some definite stuttering on 1440p. It's no biggie but I definitely felt it on these games that I tested.
Again, this was my experience and I'm just trying to part some knowledge on what I experienced since the OP who was asking has a similar processor on my system.
The OP can always seek opinions from other users, its not like I'm saying this is what he would most probably experience.
私はオタクではありません。
https://linustechtips.com/topic/1120113-plz-help-is-noob/#findComment-13017664
