Hey all,
I have a phanteks p350x, which has an 3 pin, aura cable, which ideally would plug into my mobo, however the asus pirme x470 only has 12v 4 pins. So my plan, is to create a custom calble to go from the Corsair Node pro, to tthe phanteks p350x rgb connector.
So does anyone know the pin layout of the Node rgb header?
Phanteks rgb connector:
Node pro:
Image result for Node pro cable 3 diagram
So to summarise: Connect p350x drgb to node pro rgb headers. they are both 5 volts i beleive.
https://linustechtips.com/topic/1119802-node-pro-to-p350x-rgb-adapter/
