Hi, I've been having trouble with the ethernet cable on my motherboard. When I plug in the ethernet cable on the ethernete port on the motherboard, it doesnt seem to detect the cable. I have tried the ethernet cable on other devices like a laptop and it seems to work just fine. When I troubleshoot the network, it says "unplugged ethernet connection.". Is the ethernet port on my motherboard dead?
https://linustechtips.com/topic/1119637-dead-ethernet-port/
seems like it. I had a port on a laptop once where it was a little on the large side and caused my connection to drop all the time and would have to prop the cable in a way that would allow the pins to contact the cable. Do you get anything if you wiggle the cable around in the slot?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1119637-dead-ethernet-port/#findComment-13014273
a few days ago I would get the same internet drops and would wiggle it to get the connection back, but now even the wiggling doesnt solve it. The orange light turns up at times and then starts identifying the network, but after a few moments it would show an "unidentified network" or "Unplugged network cable". I also noticed that the yellow light doesnt seem to turn on, only the orange one does. When it shows unidentified network only the orange light is up, but when it shows unplugged network cable, nothing lights up.
https://linustechtips.com/topic/1119637-dead-ethernet-port/#findComment-13014278
Ive seen in other forums where they reset the bios and it worked for them, do you think this will work in my case? or is the port just completely dead?
https://linustechtips.com/topic/1119637-dead-ethernet-port/#findComment-13014279
Well if you're getting some connectivity.. it could be worth a try. I would also try and get the latest drivers for your NIC as well.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1119637-dead-ethernet-port/#findComment-13014283
If the troubleshooting above doesn't work, I'd just get a USB 3 Ethernet adaptor, you can also get a combination one that has like 3 USB ports + gigabit Ethernet for not much money.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/1119637-dead-ethernet-port/#findComment-13014359
I'm actually planning on buying a NIC, would there be any NICs that you can suggest?
https://linustechtips.com/topic/1119637-dead-ethernet-port/#findComment-13014390
If you can get them where you live, most people prefer an intel NIC.https://www.amazon.co.uk/Intel-Gigabit-1000-1000Mbit-networking/dp/B001CXWWBE/ref=sr_1_fkmr0_1?keywords=intel+pci+nic&qid=1572691674&sr=8-1-fkmr0
[edit] Sorry forgot to @ you
@mavmlim
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/1119637-dead-ethernet-port/#findComment-13014392
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/1119637-dead-ethernet-port/#findComment-13014401
32 minutes ago, mavmlim said:
was actually looking at this https://www.newegg.com/global/ph-en/intel-expi9301ctblk/p/N82E16833106033, I also saw it on PCpartpicker
@paddy-stone
Yep, should be OK I would think. I don't use pcie adaptors myself, but if I did I would go with an intel NIC... I prefer USB adaptors if I need them as I don't like using my pcie slots, as I need them for other things.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/1119637-dead-ethernet-port/#findComment-13014457
ayt thanks so much bro appreciate it!
https://linustechtips.com/topic/1119637-dead-ethernet-port/#findComment-13014460
