31 minutes ago, Lttdotcom said:
I have amd r5 1600x stock clocks and 1070 ti and mobo is b450. Since those new zen2 processors came, i have been thinking them. So the main question is it worth to upgrade to for example r5 3600 or r7 3700x? Or do i just go for 4-5years with 1600x.
Thanks
Imo - keep it. 1070ti isn't that powerful and a 1600x is plenty wide for most tasks.
Reassess when you upgrade your GPU.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1119475-worth-or-not/#findComment-13013065
