1 hour ago, wako7654 said:
non-noctua, i have them at front
Your front fan is a noctua, so the rear cannot be from noctua? I dont understand that argument...
I recently bought a Noctua NF-S12A PWM chromax.black.swap, excellent performance and doesnt look bad:
https://noctua.at/en/nf-s12a-pwm-chromax-black-swap
If you don't want the Noctua's. Check out Corsair's ML fans. They are nearly as good as the Noctua fans, but cost less and look better. There are also RGB versions of the ML fans, if your into that.
Join HWBot or OCN
#1 3DM Fire Strike Ultra score in the world.
#2 3DM Time Spy Extreme score in the world.
#3 3DM Fire Strike Extreme score in the world.
#7 3DM Sky Diver score in the world.
#8 3DM Fire Strike score in the world.
#12 3DM Time Spy score in the world.
All scores obtained with 8600K + 1x 1070Ti. Links in bio
IMO if you commit to Noctua with all your fans its not a bad look, but yea tan and brown...
Silent Wings 3
Noctua redux? cheaper and better looking, basically their last generation stuff and a neutral grey.  They dont have all the latest innovations but you pay 50% less for 5% less performance.
15 hours ago, wako7654 said:
need one with better aesthetics
Lian Li Bora Digital.
http://www.lian-li.com/bora-digital/
SILVER GLINT
CPU: AMD Ryzen 7 3700X || Motherboard: Gigabyte X570 I Aorus Pro WiFi || Memory: G.Skill Trident Z Neo 3600 MHz || GPU: Sapphire Radeon RX 5700 XT || Storage: Intel 660P Series || PSU: Corsair SF600 Platinum || Case: Phanteks Evolv Shift TG Modded || Cooling: EKWB ZMT Tubing, Velocity Strike RGB, Vector RX 5700 +XT Special Edition, EK-Quantum Kinetic FLT 120 DDC, and EK Fittings || Fans: Noctua NF-F12 (2x), NF-A14, NF-A12x15
Noctua now makes Chromax fans.
https://noctua.at/en/products/product-lines/line-chromax
Choose black fans  !
Or yes, Silent Wings 3 from be quiet!
Great aesthetics on both, but Noctua is the god of air cooling.
Now, fashionable air cooling !
I just got black/grey noctua fans myself, they look awesome! And I kinda hate the brown /beige ones they're selling...
And they seem to be of excellent quality I have to say,  very silent,  powerful and run very smooth,  pretty much don't even notice them at 2000rpm.
Be careful with bequiet,  I'm currently trying to get 2 of them to work but seem not be able to control them, they're 3 pin connectors so I think that's why,  still trying to figure this out though,  so my verdict isn't final yet,  just saying.
-Scott Manley, 2021
System specs and temps?
Where are you shopping / located? Budget?
