4 minutes ago, Skoolby said:
Building my first computer on my own and i was wondering if a 240mm radiator would fit in the front or the top of the Fractal Design Meshify C case, i want to use the Hydro Series H100i RGB Platinum with a Z390 Designare board, would it fit??
Yes give me a moment to find what ya need.
Link to manual - page 16 (PDF page 19) https://www.fractal-design.com/wp-content/uploads/2019/07/Meshify-C-MAN.pdf
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
2 minutes ago, Skoolby said:
thank you, though im a little worried, the literal specs of the cooler say 277 even though its advertised as 240, will it still fit??
Yes without issues
Gaming PC:
Linux PC:
cool, thanks!
Because you got at least 360mm of space in the top and front and you'll only need 277mm
Gaming PC:
Linux PC:
Yes it will work, the only limiting factor will be your GPU length.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Just now, Skoolby said:
i should have included that in the first post, im using an RTX 2070 Super
which RTX 2070 Super... Custom Variants from the likes of Gigabyte, Asus etc... can be to long and cause conflict with the ability to install a front mounted radiator.
Community Standards
"Beast Mode"
On 11/1/2019 at 9:56 AM, Skoolby said:
Gigabyte's
Which Gigabye 2070 Super? They have the Gaming OC which is 287mm long (barely fits) and the Aorus which is 290mm long (will not fit).
With a front Mounted rad, you only have 288mm of GPU clearance
