Headphones with two sources
Solved by samcool55,
What I do is use the line-in on my pc.
If they are all 3.5mm you can do the following.
PS4 -> PC line in (that's the blue one) -> PC output = whatever you want.
It won't work straight away. In audio manager (or whatever it's called) you need to tell it you want to listen to the line-in signal.
I use this method to pass-through the audio from my raspberry pi to my pc speakers. Works surprisingly good.
