A few weeks ago, I helped a friend of mine install Windows on his MacBook Pro with bootcamp.
However he came to me yesturday and said it's now broken.
I looked at it and basically when he selects to boot into Windows, there is no display.Either that or it try's to load, fails and then boots into Mac OS.
Any advise on how to solve this problem? If it was a native Windows PC have trouble, I would just reinstall the entire OS but this a Mac, so not so sure.
https://linustechtips.com/topic/1119066-mac-bootcamp-help/
Just use the Bootcamp utility in macOS to remove the Bootcamp install and install Windows again. Tell your friend not to mess with the display drivers next time.
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/1119066-mac-bootcamp-help/#findComment-13009909
I see.
Though I doubt he knows how to mess with the display drivers.
https://linustechtips.com/topic/1119066-mac-bootcamp-help/#findComment-13009974
