What program was Linus using?
Go to solution Solved by ACEHACK,
https://www.hwinfo.com/
and
https://www.msi.com/page/afterburner in other videos
there is also aida64, cpuz, gpuz
I was watching the recent $5000 PC from 10 years ago and was wondering what program Linus was using to check not just the FPS, but those other numbers (I think I know what they are, but my eyesight's too bad to tell)
Just here for some fun.
PC Build 1: Great Ape (Main Rig) > https://pcpartpicker.com/user/DJ_saiyanprince/saved/nKjHGX
CPU: Ryzen 3700X
GPU: ASUS GTX 1070Ti 8GB ROG STRIX
PSU: SeaSonic FOCUS Plus Platinum 750 W
Mobo: MSI MPG B550 GAMING CARBON WIFI
Case: Corsair 4000D
PC Build 2: Piccolo (Emulation/ITX/Transportable) > https://pcpartpicker.com/user/DJ_saiyanprince/saved/tDBdHx
CPU: Intel i5-11400
GPU: EVGA GTX 1060 3GB SC
PSU: EVGA SuperNOVA GM 550 W
Mobo: ASRock Z590M-ITX/ax
Case: Silverstone RVZ03
♪♫ "2-to the-1-to the-1-to the-3 I like good OC and RGB. Configure so much, you wouldn't believe. And I get more blue screen than a Walmart PC" ♪♫
https://linustechtips.com/topic/1118256-what-program-was-linus-using/
Not sure what timestamp in the video, but I'm just gonna guess it's MSI Rivatuner you were seeing.
