If you have complete disregard for warranty then get the 780.
Buying used graphics cards is like buying used underwear, you run the risk of inheriting somebody else's skids.
god's love ,Exodus 31:15 , Deuteronomy 17:2-7 , Deuteronomy 13:13-19 , Leviticus 24:16 , Leviticus 20:9, Leviticus 20:10 , Leviticus 20:13 , Deuteronomy 21:18-21 , Matthew 18: 7-9 , 1 Corinthians 14:34-35 , 1 Timothy 2:11-12 , Leviticus 25:44, Exodus 21:20 , Titus 2:9 , Isaiah 13:15/16/18 , Hosea 13:16 , Numbers 31:17-18
https://linustechtips.com/topic/111764-advice/#findComment-1494233
What kind of return policy does the refurb have?
My System Specs: (Short list) i7 4770k, GTX 780, many SSD's, a 2 TB HDD(deceased :( ), Corsair 650D. Full list: http://pcpartpicker.com/user/kchriz6097/saved/8dh7YJ
Upgrade Plan: Acquire some Black Noctuas then add 16 or 32GB of 2133MHz memory
https://linustechtips.com/topic/111764-advice/#findComment-1494236
Depends on what warranty the refurb comes with. Here we get the same warranty on refurbs as we do with new products so the choice would be obvious. You're not really risking much with the refurb though. I've bought plenty and I'm yet to have one fail.
https://linustechtips.com/topic/111764-advice/#findComment-1494336
The 780 has a 1 year limited warranty
what store is selling the 780.
Specs: Cpu: i7-4790k@4.5ghz 1.19v Cooler: H100i Motherboard: Msi z97 g55 SLI  Ram: Kingston HyperX Black 16gb 1600mhz GPU: XFX R9 290X Core Edition PSU: Corsair HX850  Case: Fractal Design Define R4 Storage: Force series 3 120gb ssd, sandisk ultra 256gb ssd, 1tb blue drive  Keyboard: Rosewill RK9100x Mouse: DeathAdder  Monitors: 3 22 inch on a triple monitor mount
https://linustechtips.com/topic/111764-advice/#findComment-1494479
