I'm willing to give up folding for mining, if my CPU can actually mine. I don't have a GPU that can mine (and if my onboard can, I sure as hell am not using it), so I would have to mine on my CPU. I'm running Windows 7, ATM.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/111726-how-can-i-start-mining/
Buy 6000 series or newer AMD card on used market.
Plug into computer.
Start mining.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/111726-how-can-i-start-mining/#findComment-1493522
Not worthwhile, you might as well leave a bunch of lights on in your house 24/7 because that would be that equivalent of what you would be doing mining with a CPU.
My grandma uses all 75 watt bulbs, and my OC only draws 80.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/111726-how-can-i-start-mining/#findComment-1493543
Plug into computer.
Start mining.
Is CPU mining REALLY that terrible for me? How long would it take for me to make $1 USD?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/111726-how-can-i-start-mining/#findComment-1493551
The great thing about mining is once you get a lower end card, you can make money from the card for an even better one. From there, you can upgrade once more, and again and again. Sure, it will take a while for the steps to happen unless you get really lucky mining a low end coin now, and it explodes later on, then you're set.
I'd take his advice as to I recommend you do the same.
//CCap
//ccap
https://linustechtips.com/topic/111726-how-can-i-start-mining/#findComment-1493553
//CCap
I was curious about CPU mining so I could do that. Since TigerDirect accepts them now...
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/111726-how-can-i-start-mining/#findComment-1493577
This would be a good place to start:
Dancing Linus, you're a smartass.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/111726-how-can-i-start-mining/#findComment-1493580
BTC or LTC?
I learned to mine from this tutorial.
https://linustechtips.com/topic/111726-how-can-i-start-mining/#findComment-1493637
BTC or LTC?
I'm kinda thinking Bitcoin.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/111726-how-can-i-start-mining/#findComment-1493726
Follow that tutorial, just do this program and pool instead.
http://guiminer.org/
http://mining.bitcoin.cz/
Alright, I'll try it this weekend after my SSD upgrade.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/111726-how-can-i-start-mining/#findComment-1493819
A very, very long time. Depending on the coin it's probably years or potentially even infinite (i.e. you'd never finish a block). Even with a pool, you could be looking at years (again depending on coin).
https://linustechtips.com/topic/111726-how-can-i-start-mining/#findComment-1493904
You could be better off taking out a loan. Whether it be from a bank, a sibling, or just a friend. Borrow a hundred or so dollars for a dedicated gpu, 7770, 7790, r7, r9 260x, something of the sorts, and you could pay them back decently fast with mining.
The beauty of mining is that you are able to mine a low end coin, and use the coin you've mined like stock. Hell, you don't even have to mine it. If you bought into a low end coin, let's say it's conversion rate is something like .50c per coin. You spend $100 on coins, leaving you with 200 coins. Let's say that tomorrow is a fantastic day for the coin, and it goes to 1.00 per coin. Now if you convert the coins to USD, then you've just profited $100.
Not really recommended you do that, since you could lose some money during the whole converting to LTC, and then to BTC, and then finally cashing out. By that time, you could potentially lose a lot of money, and it's just something cool to think about. Keep it in mind if you come across some money.
//CCap
//ccap
https://linustechtips.com/topic/111726-how-can-i-start-mining/#findComment-1493998
DO NOT MINE BTC with your CPU!
Mine CPU only coins!!!
Network/Homelab build log Main PC: "Aqua Blue"  Server: 15TB+ "Blue Lightning"
3900x, 32GB RAM @3200mhz, RTX 3090, 2.5TB+ SSD Storage, 4x2560x1440 monitors
Samsung Galaxy Z Fold2 5G, +2x Note 9
https://linustechtips.com/topic/111726-how-can-i-start-mining/#findComment-1495516
What coin do you think would be good for a CPU?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/111726-how-can-i-start-mining/#findComment-1496435
Probably a momentum algorithm coin like protoshares or memorycoin, not sure if you'd make much of a profit tho since cpu hashing rate is so low, but a momentum coin would probably give you the fastest speed for a cpu.
CPU: Intel i5 3570k @4200 | Motherboard: ASUS P8Z77-V LK | RAM: 8gb Crucial Ballistix @1600 | GPU: Evga GTX 660 TI x2 SLI | Case: Corsair C70 | Storage: WD Black 1TB, Samsung 830 126GB SSD, Kingston V300 120GB SSD | PSU: Corsair HX850 | Display(s): ASUS 2ms 24inch 1920x1080 | Cooling: Corsair H100i | Keyboard: Razer BlackWidow Ultimate 13 | Mouse: Razer Naga 13
https://linustechtips.com/topic/111726-how-can-i-start-mining/#findComment-1497129
