Yes just make sure you get the right 3 or 4 pin.
https://linustechtips.com/topic/1116387-fan-splitters/#findComment-12988438
4 minutes ago, FlaxDrop said:
What would be the right ones? Theres no different types of 3-4 pin fan headers right?
Well there's 3 pin, and then there's 4 pin.
https://linustechtips.com/topic/1116387-fan-splitters/#findComment-12988696
Fan power and RGB control/power are done with two separate cables (except some proprietary which use their own single cable). For RGB fans you have PWM for fan power. Most mobos have at least 2 system fan headers. RGB fans tend to include power splitter for 3 fans. But if you get one separately, take note what kind of cable fans are using. To be safe you could use manufacturers own splitters.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1116387-fan-splitters/#findComment-12989534
