I built this PC earlier around February. The case is custom made out of acrylic sheets and wrapped with 3m vynyl. Inside is an i9-9900k, 1080ti, 32GB of ram at 3200mhz on the asus z390i. The processor is cooled with a Corsair H115i 280mm radiator. Here is a video of it https://youtu.be/5PZX2VfTb8o
https://linustechtips.com/topic/1116285-custom-zelda-itx-case/
3 hours ago, xARACHN1D said:
Is it a MicroATX build? its awesome. Can you send a link of what case you used?
It's a mini Itx build. Sorry, but I made the case myself. However my inspiration for it was the ghost s1 so you might check that one out. https://www.louqe.com/
https://linustechtips.com/topic/1116285-custom-zelda-itx-case/#findComment-12988865
