Male vga to usb 3.0?
gta6287
Is there such thing?
< ̄`ヽ、       /  ̄ >
 ゝ、  \ /⌒ヽ,ノ   /´
   ゝ、 ( ( ͡◉ ͜> ͡◉) /
     >     ,ノ
sorry for my bat englandski
What are you trying to do
Dunno. Asking for friend. He just wants that specific cable
< ̄`ヽ、       /  ̄ >
 ゝ、  \ /⌒ヽ,ノ   /´
   ゝ、 ( ( ͡◉ ͜> ͡◉) /
     >     ,ノ
I can think of just one device .... some usb capture capture card.
ex Epiphan VGA2USB : https://www.ebay.com/itm/Epiphan-VGA2USB-LR-portable-USB-Video-Grabber/123888712833?hash=item1cd857bc81:g:tH8AAOSwWDxdZVUU
or this: https://www.ebay.com/itm/Vidyo-Room-VGA2USB-Portable-External-VGA-Screen-Capture-Device/401842605890?hash=item5d8faf8f42:g:GNgAAOSw~hpdTbVu
If he wants to capture stuff, it would better to use HDMI to capture, or DVI, or Displayport.
Well I don't know what he's trying to do, but it's probably not going to work like that
There are a few different types similar to what you are asking about, i.e. a USB connection to a VGA connection and all seem to be available on the inter-webs.
USB 3.1 type C to VGA (female) and USB with power delivery, adapter.
USB type C to VGA adapter cable (male).
USB 3.1 type C to VGA converter (female).
Lastly and probably the closest to the correct answer would be...USB 3.0 to VGA adapter (female).
However, that output is through the female coupling so your friend would also need the VGA gender changer, HD15 Male/Male adapter.
Those who deny freedom to others deserve it not for themselves (Abraham Lincoln,1808-1865; 16th US president).
Yes, but those are "video cards" and usually there's two versions
1. software video card: you install a driver on the computer which creates a software video card and the driver sends the fake screen bitmap to the chip on the USB and the chip produces a vga signal. These use a lot of cpu especially if it's not highly compressible data (like application windows with lots of blank space), if you watch a movie where everything changes from frame to frame, the cpu goes up
2. some kind of thunderbold/ hdmi/displayport over usb type c  adapter, where the laptop or whatever has to support redirection of video card image through usb type c ... then the chip on the usb receives hdmi/displayport signal and converts that to vga signal
Basically these two kinds are one direction only ... from usb to vga ... not the other way around.
I gave example in my post above of  capture cards, which basically take analogue signal and convert it to digital and you have it available on your computer through usb, basically as if you're watching a usb webcam.
I originally thought the guy wants some kind of long range extension for vga, but usb isn't good for that... there are VGA to coaxial/BNC or ethernet converters if length is the purpose.
