so i have 1333 MHz ram it shows in task manager as 1333 but speccy and cpuz is showing 667.3 MHz
its showing slot 1 and 3 as 800 MHz
and slot 2 and 4 are showing as 667 MHz cpuz is showing 685 and 761 MHz
i have a gigabyte GA-Z77P-D3
or should i not worry about speccy and listen to task manager as it working fine
Faza_Fox
https://linustechtips.com/topic/1115785-help-with-ram/
DDR stands for double data rate. So. Double the number you see there, and you get what it runs at.
You likely have two different speeds of RAM. 1333mhz and 1600mhz.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1115785-help-with-ram/#findComment-12983392
