Corsair HX1200i and Cablemod kit?
Solved by seon123,
30 minutes ago, kaptkrunch said:I must be looking at this wrong then, under my model name it says,
C-Series AXi / HXi / RM (Yellow Label) Corsair® HX1200i
Yellow label?? The label on mine isnt yellow... Where on cablemod does it say type 3???
So if they arent type 3 and I dont have a yellow label, then cablemod isnt compatible. Thats what I was asking. thanks
There are two versions of the RM. One with a yellow label on the side, and another with a gray label on the side. The yellow label part doesn't have anything to do with your HXi.
