a nice guide with good info. may not have all the info but its a good start. one thing he missed was that you can get an fan controller like aquacomputer aquaero controller to control your 3 pin fans or 4 pin there probably some Lamptron 5.25 fan controllers that can do this too. the advantage is the rpm stays the same instead of ramping up then backing off. another thing to convert your 3 pin fans to pwm is a pwm convertor  Phobya 4Pin PWM to 3Pin Converts 4-Pin PWM signal to 3-Pin Voltage Controlled.
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
https://linustechtips.com/topic/1113903-nice-guide-on-info-about-fans/
