I got this idea after the DIY monitor video... what if I bought the panel from a 1440p 144hz monitor like the ASUS PG279Q and a control board to go with it. Could I technically make my own gaming monitor just by building my own case and VESA mount for it? Use some aluminum on the inside for the VESA mount and 3D print a case and bezel for it... Has anyone tried this? I'm very tempted because you can get a fully functioning monitor for less than half the price.
https://linustechtips.com/topic/1113728-diy-1440p-144hz-monitor/
Hmm,, i dunno if thats a smart idea.
Cheap replacement panels are generally not A grade panels. They could have terrible uniformity and/or more dead pixels than normal.
I mean what if the panel u get turns out to be crap quality?, returning based on things like uniformity and dead pixels will likely be a right pita.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
Is that usually the case when it comes to buying panels on AliExpress?
Cant say from personal use, but its not unheard of thats for sure.
