Monitor suggestion
Go to solution Solved by balexandre,
@Dipypang you have the same specs on the LG 27GL850
the good thing is that LG uses their nano-IPS technology
from https://www.lg.com/us/monitors/lg-27GL850-gaming-monitor
  • Nano IPS 1ms response time
  • 27” QHD (2560 x 1440) Nano IPS Display
  • NVIDIA® G-SYNC® Compatible
  • Adaptive-Sync (FreeSync™)
  • 144Hz refresh rate
  • HDR 10 (this means an app or game can see it's a HDR screen - it's only metadata - thanks @Glenwing)
here's a very detailed comparison :)
https://www.rtings.com/monitor/tools/compare/gigabyte-ad27qd-vs-lg-27gl850/757/912
Hi guys,
I'm searching for a monitor with the following specs i wanted with budget max $600:
- 27" 2560x1440 QHD Display
- 144hz Refresh Rate
- 1-5ms Response Time
- G-SYNC Compatible
- IPS Panel
- HDR Vesa certified at least 400
I want it for gaming and creativity (Adobe Ps, Ae, Pr, etc)
Here is one of my candidate with all the specs i want included (Gigabyte Arous AD27QD):
https://www.newegg.com/amp/black-gigabyte-aorus-series-aorus-ad27qd-sa-27/p/N82E16824012006&ved=2ahUKEwjY2LGPx5PlAhV17XMBHeDTDa4QFjAFegQICRAB&usg=AOvVaw1r5na2YlRSP1IT8G_Uhn7G&ampcf=1
https://linustechtips.com/topic/1112674-monitor-suggestion/
That Gigabyte is the monitor I was going to recommend.
Just don't expect HDR from it. HDR400 monitors aren't really HDR.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12958768
28 minutes ago, Dipypang said:
Hi guys,
- G-SYNC Compatible
- IPS Panel
If you are aiming to use this monitor for content creation you should also consider colour accuracy as a primary factor.
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12958795
What do you think about that monitor's color accuracy. I see it covers 100% sRGB although for Adobe only 88%. What do you think?
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12958901
I believe it can be calibrated quite good, but one needs a tool for that, something like the X-Rite Colormunki Smile, Colormunki Display or Datacolor Spyder 5 express or Pro.
I ordered a Colormunki Display last week, should arrive today or next week, and I plan on purchasing that Gigabyte monitor next week.
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12958942
Wow nice ??
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12958956
NZXT H440 | i7 8700K @ 3.7GHz | Asus TUF Z370 | (4x8) 32GB | GTX 1080Ti | 1x Asus ROG Swift PG349Q + 2x Dell S2417DG | SSD NVMe (960+256) + HHD Barracuda 2Tb
AudioEngine D1 | Aune X7s | AudioEngine A5+ | HD 6xx | PC 37X | Z60 7.1 | Hart Audio cable set | G502 | G915 TKL
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12959284
Ok, that's pretty good, no issues there.
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12959897
  • HDR 10  <-- LOL!
Overall still Aorus is better lol.
For the HDR, Aorus is in the VESA HDR product list while LG isn’t. The LG’s HDR is actually below vesa’s minimum to be certified as hdr monitor.
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12960054
if you are looking into that page stats, you can see that a lot of numbers are low because the screen was not correctly calibrated...
but hey ... as long as you're happy!
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12960123
Here's another recommendation
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12964945
Both of them looks great, but I imagine that if you have a calibration tool the LG will be better overall?
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12965827
I believe that if the LG would be correctly calibrated, it would have better specs... some results are to way off to be "correctly calibrated", I think the tests are simply "factory screens"...
but remember, it's all about what are you doing with it, video/photo editing where you need colors to be precise vs video and gaming where you really don't need that precision to be perfect!
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12965849
So if I want it mainly for gaming they're both good?
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12965853
both amazing for the price ... then again, I would think going ultrawide :)
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12965885
Awesome, thanks! I thought about ultra wide, but I doubt that I have room here. for me 27" is the largest one I thought of buying. Will there be an advantage of getting an Ultrawide one?
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12965895
it's only 8 cm  higher...
27'': 614 x 365 mm
35'':  836 x 445 mm
Yes! the immersion in gaming plus more and more games have now Wide Screen support... is totally worth it (of course, it's all of a personal taste, and I do love it!)... try first, go to a store and check the ultra wide ones...
the LG price vs the Benq EX3501R is almost the same... (that's why I'm so keen to swap my 2 screen for it)
you also have more good ultra wide screens for the same price range
- BenQ EX3501R (3440x1440, VA, 100Hz, 4 ms, HDMI/DP/USB-C)
- Asus XG35VQ (
3440x1440 VA, 100Hz, FreeSync, 4 ms, 2500:1, DP/2xHDMI)
- MSI MAG341CQ (
3440x1440 VA, 100hz, 4ms, 3000:1, DVI/HDMI/DP)
But remember, no matter what choice you make, it's all about YOU! it's your feeling and happiness that comes first, so, 25'', 27'' or ultra wide, it's all about your money vs what you will fell when using such monitors :)
I know I will only be happy with a ultra wide :D
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12965927
Check those:
A) AOC CQ32G1 https://eu.aoc.com/en/gaming-monitors/cq32g1 (3000 Croatian Kuna)
B) LG 32GK650F https://www.lg.com/us/monitors/lg-32GK650F-B-gaming-monitor (3500 Croatian Kuna)
C) Acer XZ321QU https://www.acer.com/ac/en/US/content/model/UM.JX1AA.003 (3500 Kn)
D) AOC AG322QC4 https://eu.aoc.com/en/gaming-monitors/ag322qc4/specs (3700 Kn)
3000 Croatian kuna is about 450 US Dollars or 400 Euros. 3700 Kn is $550 or 500€
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12966118
4 hours ago, Skeith_ said:
These are VA panels though?
You will get better features with VA panels, IPS's have better image across wider angles (then again, we're always looking in front, and the curvature makes you don't get far from the edges)... as today, I would rather have an VA panel, you save the money and you get better refresh rates and contrast levels than IPS panel... for the same amount of money or course... don't wanna get challenged by a X35 screen :P  :)
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12966479
3 hours ago, 191x7 said:
Check those
those are not exactly ultrawide :)
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12966487
I thought that IPS means better colours overall along with the better viewing angle. So what 27" VA panel will be the best in this regard?
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12966506
Yes, IPS panels you get get better color reproduction overall ... but not with good VA Panels, and yes, no doubts, better image in wider angles ... but are you thinking of siting down aside and watch the screen? or havin' the screen do be a "public" display where you want to see it from afar and maybe side ?
if it's mainly to see in front of the screen, why spend money on a IPS panel where we can get a great VA Panel for much less?
IPS:
+ better color reproduction
+ better colors across wider view angles
- refresh rates
- response times
VA:
+ better refresh rates
+ better contrast
- not good view angles
- color reproduction lower than IPS
TN:
 don't even look at those ... I have 2... do. not. buy. them.
if you want a screen for gaming without spending much: VA panels will delivery better 2 things: contrast (HDR!) and refresh rates (great for FPS games)... if you want for video/photo editing and color correction ... IPS!
Sorry, I'm not into 27'' panels ... I only did my homework with 34'' and larger.
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12966529
@Dipypang@balexandre
FYI , the LG GL850 has below expected HDR results due to the results of their color tests, which due to their testing method is more accurate and thus harsher than most other reviewers.
They explain it in response to a comment.
Comment:
"You’ve quite obviously measured the DCI-P3 coverage with the monitor in sRGB mode. Compare the black triangles between the DCI-P3 and Rec. 2020 charts. This should also have been obvious with such a big difference between a 78% measured coverage and a 98% advertised coverage (as confirmed by other reviews).
Reply:
"No, we didn’t measure it in sRGB mode. The difference in our measurements and the advertised specs is due to the way we measure color gamut. When measuring DCI-P3, we limit the primaries to the DCI-P3 color space. The vast majority of other reviewers don’t do this. DCI-P3 can only be sent as Rec. 2020, and most other sites simply send Rec. 2020 and measure how much of the DCI-P3 color space it covers. This isn’t very accurate though, as the colors are often over-saturated. By limiting the primaries to DCI-P3, we obtain an (arguably) more accurate measurement of DCI-P3 coverage. Because of this difference though, almost every monitor we’ve tested shows a smaller DCI-P3 coverage than other reviewers or the manufacturer’s posted specs."
So when comparing reviews within rtings, its a fair comparison.
When comparing against other reviewers, ull need to check their testing method.
For example rtings also use a different pixel response time measurement method vs say tftcentral.
0-100% data points vs 10-90% data points respectively.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/1112674-monitor-suggestion/#findComment-12966756
